Revolutionary Mitutoyo MACH Ko-ga-me®
Revolutionary Mitutoyo MACH Ko-ga-me® compact, 3D CNC measuring system configures to almost any process
(Aurora, IL) Mitutoyo America Corporation announces availability of the innovative, new MACH Ko-ga-me® measurement head – designed to bring full capability to applications where a compact, high-performance, 3D CNC, 2- or 3-axis measurement system would be ideal. The Mitutoyo MACH Ko-ga-me® is small-sized, requiring only a minimal envelope (17.3” [440mm] x 16.1” [410mm] x 4.7’ [120mm]) and weighing 17.6 lbs. (8kg). This makes MACH Ko-ga-me® agile and easy for a customer to mount – using either an available fixed base (wherein the workpiece moves during measurement) or using a moving-axis mounting system of the customer’s own design. Mitutoyo MACH Ko-ga-me® measuring systems are available for horizontal or vertical installation and can be used in stand-alone applications or integrated into work cells. MACH Ko-ga-me® is ideal for inspection of large or small workpieces and offers a wide range of available measurement probes including touch-trigger, optical or constant contact probing. The Mitutoyo MACH Ko-ga-me® is available in 40mm, 80mm, and 120mm stroke models and offers a resolution of 0.02µm, a measuring accuracy from 1.5 x (3L/1000)µm, (more) MACH Ko-ga-me, D2 Pg. 2 of 2 a maximum drive speed of 200mm/s (1 axis) and has a maximum acceleration of 0.4G (1 axis). In addition the unit supports probes including: TP200+PH6, SP25+PH6M and QVP (QuickVision® Probe).
