AURORA, IL – March 6, 2018 – Mitutoyo America Corporation is showcasing its highest performing micrometer and caliper lines, including High-Accuracy Digimatic Micrometer, QuantuMike Series 293-Coolant Proof Micrometerand its IP67 ABSOLUTE Digimatic Coolant-proof Calipers. All three products are best in class and feature unique capabilities.
High Accuracy Digimatic Micrometer
  • The first micrometer to offer 0.1µm/5µinch resolution measurement.
  • The High-Accuracy Digimatic® Micrometer utilizes the Absolute® rotary sensor, which reduces instrument error to ±0.5µm to deliver high-accuracy with no trade-off in operability.
  • Features an extremely rigid frame for stable measurement and a constant-force barrel/spindle mechanism eliminates the possibility of over speed errors.
  • Transference of body heat reduced with use of a dual heat shield design, minimizing errors attributable to thermal expansion while handheld measurements are performed.
  • Available with SPC Output.
  • Up to 4X faster spindle feed over standard micrometers. 2mm per thimble-revolution as compared to the standard 0.5mm.
  • An additional comparison to conventional micrometers, QuantuMike’s spindle positioning time is reduced by about 60 percent while overall measurement time is decreased by as much as 35 percent.
  • QuantuMike provides accuracy at an industry-leading ±1μm/.00005” throughout its measuring range.
  • Rated a high IP65, the QuantuMike Series is totally protected from dust and protected against low pressure liquid or coolant
  • Calipers rated a high IP67, total protecting the tool from dust and if immersed in liquid or coolant for a short period, will still work at 100 percent measuring accuracy.
  • A Larger LCD of 9 mm, a 22 percent increase in height for improved visibility.
  • The automatic power on/off shuts down the LCD after 20 minutes of inactivity, but the ABS scale origin is unaffected. Power is restored to the display when the slider is moved.
