Request Technical and Software Support
If you need technical support, our highly skilled engineers and technicians are available to help you when you need it. Simply fill out this form and someone will contact you regarding your request.
  • If you live outside of the US or Puerto Rico, please click here.
  • If you aren’t sure what product group fits your need, click here for details about each one.
    Mitutoyo Product Groups
    Mitutoyo products can be divided into eight general groups. Explore the list below to see which group includes the solutions you’re looking for.
    • Coordinate Measuring Machines
      • CNC CMM – Bridge Type
      • CNC CMM – Car Body Measuring Type
      • CNC CMM – High Accuracy
      • CNC CMM – In-Line Type, High-Speed
      • CNC CMM – Ultra-High Accuracy
      • Manual CMM – Bridge Type
    • Vision Measuring Systems
      • CNC
      • CNC Image Stitching
      • CNC Scanning
      • Manual
      • Multi-Sensor Touch Probe
    • Form Measuring Systems
      • Contour Measuring Instruments
      • Dual Type (Surface Roughness/Contour)
      • Roundness Measuring Instruments
      • Surface Roughness Testers
    • Optical Measuring Systems
      • Finite Conjugate Microscope Objectives
      • Infinity Corrected Microscope Objectives
      • Portable Optical Inspection
      • Profile Projectors
      • Microscopes
      • Microscope Heads
      • Video Microscope Units
      • Vision Units
    • Sensor Systems
      • Laser Scan Micrometers
      • Laser Scan Micrometer Display Units
      • Linear Gage/Mu Checker Counters
      • Linear Gage/Mu Checker Probes
    • Test Equipment
      • Hardness Testers
      • Micro Hardness Testers
      • Rockwell Hardness Testers
      • Rubber or Plastic Hardness Testers
      • Vickers Hardness Testers
    • Digital Scale & DRO Systems
      • Counters
      • Digimatic Scale Units
      • Linear Scales
    • Small Tools and Data Management
      • Calibration Equipment
      • Calipers
      • Caliper Gages
      • Data Management (SPC)
      • Hardware
      • Height Gages
      • Indicators
      • Inside Measurements
      • Micrometers
      • Reference Gages
      • Stands
      • Tension Gages
      • Thickness Gages
    • Finescope
      • Microscope units suitable for observation of a variety of objects: metal surfaces, semi-conductors, LCDs, resins, etc.
