TM Series Microscope offers best-in-class performance.
Mitutoyo America Corporation announces the release of the new TM Microscope Series, with enhanced features and ergonomic design.
Mitutoyo TM Series is a toolmakers’ microscope well suited for measuring dimensions and angles of machined metals. It also can be used to check the shape of screws and gears by attaching an optional reticle. The compact body makes it ideal for use on shop floors with limited space. A C-mount camera can be connected to the eyepiece by way of an eyepiece adapter, turning the TM series into a video inspection system. With bright and clear field of view, the TM Series microscopes offer the best-in-class performance for small models.
Product highlights include:
- Newly designed LED illuminators provide enhanced observation for higher accuracy and resolution
- Modified base design with lateral notch makes the microscope easy to carry and move
- Improved extensibility by the optical camera adapter
- New AC adapter covering a wide range of voltages provides more flexibility
- Small foot print for adaptability in busy work environments
The TM Series is part of a diverse range of optical measuring products offered by Mitutoyo.
To download a PDF of the press release, click here. To download a high-res photo, click here.
